Firefox crashed and lost all my tabs
  • 2 views
  • Last reply by cor-el
Windows 7, firefox 40.0.3
My computer crashed and thus, firefox did not close properly and lost all of my tabs. Under Menu -> History, the Restore Previous Session is greyed out. Why is this? Shouldn't I be able to restore from there?
I've found replies from "jscher2000" and my sessionstore-backups\previous.js file looks like the one I want to use to restore my tabs. However I do not see how to use this file to restore my tabs.
How do I use previous.js to restore my tabs and tab groups?
Windows 7, firefox 40.0.3 My computer crashed and thus, firefox did not close properly and lost all of my tabs. Under Menu -> History, the Restore Previous Session is greyed out. Why is this? Shouldn't I be able to restore from there? I've found replies from "jscher2000" and my sessionstore-backups\previous.js file looks like the one I want to use to restore my tabs. However I do not see how to use this file to restore my tabs. How do I use previous.js to restore my tabs and tab groups?
You can backup the session files in the sessionstore-backups folder in the Firefox Profile Folder to make sure not to lose possible important session data. You can find these files in the sessionstore-backups folder:
previous.js (cleanBackup: copy of sessionstore.js from previous session that was loaded successfully)
recovery.js (latest version of the sessionstore written during runtime)
recovery.bak (previous version of the sessionstore written during runtime)
upgrade.js-<build_id> (backup created during an upgrade of Firefox)
You can copy a file from the sessionstore-backups folder to the main profile and rename the file to sessionstore.js to replace the current file (make a backup copy of the current sessionstore.js).
You can use this button to go to the current Firefox profile folder:
